How do I set the SPT value to lock to depth (in this situation 15.50m) rather than be pushed down the log by the fracture spacing items above? I tried using the alignment tools but the do next to nothing in the context. I also tried changing the order and padding of the items in the depth columns area but to no avail - SPT always gets forced downwards. I would rather the fracture spacing be pushed upwards by the SPT.
Hi Jono,
It maybe that the depth for fracture spacing is set to show at the mid point between the 2 depths which pushes the result to the end depth. I think you would need to change how that works for the SPT depth to show in the right place. Another option bay be to have a separate column for the SPT depths.
Martyn
We have previously had a separate column for SPT but it is essentially wasted space as normally the If and FI don't intersect with the SPT areas. Would it be possible to make the rangedatatext into something that can be aligned up/down?
Jono,
In addition to Maryn's comments.
The order the items are displayed in a column is the same order as they are shown in template Studio. If you want the SPT to always appear above the Fracture Spacing then make sure it is above it in Template Studio. They may help you in the situation above.
Roger
