I am trying to make it so the BH IDs do not overlap when the holes are close together in a site plan. Is there a way of offsetting them so they do not do this?
Also is it possible to change the font/boldness of the BH IDs?
Hi Abi
Please see the link below, on how to change the theming of the BH on the map
communities.bentley.com/.../default-locations-styling-theming
Hi Melanie
Thanks for the response. Unfortunately the link you've provided does not answer whether it is possible to stop the labels from overlapping when the locations are positioned so close together on the map. Is this possible?
Hi Abi, The only solution I have found to this is making separate location groups for the offending labels and offsetting labels in different directions/distances - pretty clunky but it works!
