The file set reference box is not editable in the edit metadata window for documents so when exporting the associated files in AGS the FSET cannot be changed. Is there a reason for this and can it be changed to an editable field so a specific FSET can be used?
Hi James,
I think once imported its hard set. I cant see anyway to edit the table. If you want to change its values you may need to delete the file and reimport it with the details you need.
Martyn
Hi Martyn,
My initial question may not have been as clear as it could be. In the manual under edit metadata there is a FSET reference box which can presumably be used to set the FSET. This box is however not editable. Based on the screen shot in the manual it used to be, is there any reason for it to have been changed? Current default is the Location ID but not sure this is the smartest way to do it.
