Just tried to install this on my Samsung Galaxy Active Tab 2 - Android Ver 9.
4.6Gb Storage free
1.3gb memory free
Can you tell me what is wrong?
I've asked to team for advise and will get back to you
Hi Mark, can you check to see if you are able to install the app through the Play Store on the device. I had this problem on my machine, not being able to send to my device, however I was able to install by searching and installing from the Play Store. If that doesnt help, then let us know and we can investigate further.
Hi Steve,
I am unable to find the app in the Play Store.
I think its because my tablet is not suitable.
Hi Mark, can you find out if you are using a 32bit or 64bit Android install? From looking at the specs of the device it should have a 64bit processor but the OS might not be. if you install an app such as AIDA64 from the play store, then click on inspect, you should get more info on the device....
The Kernal Architecture is the important bit, if this ends in 64 then you have a 64bit OS and we should be able to install the program. If it ends in something else then the bit rate of android will be the issue.
I get something different.
I assume this means that the app wont run on Samsung Tab Active 2'sCan Bentley provide a list of approved devices which I can choose from?
