When entering blow counts into the ASTM American Default configuration in OpenGround Cloud Professional where there is SPT refusal, the Blow Counts column auto-populates in feet (e.g., 10-20-50/0.25' or 50/0.167' ), this is also how it shows up when I generate a boring log. How do I change the display in Professional and most importantly, what expression/method should I be using in Template Studio to make the boring log template show it in inches (e.g., 10-20-50/3" or 50/2" )?
Thanks in advance!
Hi Allison
Thanks for asking about this. I think you need to replace the expression with the one below:
