Cross section template symbol and axis title changes
Is there a way to remove this symbol in the bottom left corner of cross section templates? It seems to be marking the bottom elevation of the section, but it looks like a water table symbol so I would like to remove it to avoid confusion.
I would also like to add an "Elevation" label to the vertical axis. How do I go about doing that?
Thank you!
