Tried grouping the projects by office, but when I try to save the search, the system goes down and I must restart!
From the PROJECTS list, slide to the right until you see the column marked ‘office’ see below:
GROUP projects by their OFFICE.
Picked my office and all projects associated with the office is filtered and shows up
After this, I cannot save the search or the system shuts down and restart is required.
Is there a bug?
Alternatively, is there a way for OGC to remember the projects a user has filtered.? So, the next time you open any OpenGround app (Excel, AutoCAD, Pro, Data Entry) that it shows you that list filtered just like you had it before.
Filtering can be annoying if there are MANY projects.
Hi Catherine
I've just had an update for this. Saved searches are only available inside of the projects. The reason it crashes is because this is not available outside of the projects. This option will be removed in a new release
