The question is, as we transition from GINT to OpenGround, will we be able to access the data outside the application (eg through GIS web services)? JSON or REST is the preferred method, can work with an API.
Also, how might this move affect the efforts between Galveston District and Tx GLO on tens of thousands of boring logs on the Tx Coast?
Hi Catherine
Many thanks for asking about this. Please go to the link below, fill out your query and a developer will get back to you
www.bentley.com/.../bdn-inquiry-form
Were you able to do anything with this? How did it work? I'd like to do the same.
Hi Devin, Please check out the Developers Resources Wiki for more info about working with the OpenGround API.
