Do you have wiki instructions on how to set up the Image Grid in a report template so it can produce a Core Tray photo and the From and To depth values in the text beneath the photo?
I would like to produce 2 and 4 photos per page.
Mark.Kleinman
Hi Mark
Please see: communities.bentley.com/.../how-to-setup-an-image-grid-within-template-studio
Hi Melanie,Yes I found that and have built some templates.The pictures on that page are too tiny and basically unreadable.
Under Image Alignment - Can you explain what you mean by "allocated space" does that refer to the Image Height and Width?
Is there an example of how to get the depth values to appear beneath each core box image?I tried [DepthTop] + ' - ' + [DepthBase] from the Core Information with no success.Can you (Steve) provide a better example?
Mark.K
Hi Mark,
I'm not sure what the allocated space is but you would need to adjust the Image Height and Width and text the preview until the image shows. For the expression, can you email me a screenshot of what your trying to do? I'll then review it.
Martyn
Hi Martyn,
This is the page - How to setup an Image Grid - OpenGround Wiki - OpenGround | gINT | Keynetix - Bentley Communities
I highlighted the sentence.
For an Image Grid.I am using the Core Information table to access the core tray documents (photos)
My issue is I want to pull the two depth fields and create a string like "10.00 - 14.95" under each photo. Its the depth interval.If you look at our zIT test configs for US and CA you will see CorePhoto templates I have created.I just need to get the expression working in the Image Grid.Thanks
