I am trying to set up a Data Entry Profile for truck-mounted DCP tests, and I am running in to a bit of a problem. When setting up the "Data Input" step for the profile I want to use a "DCP Testing" grid that I created which uses a "DCP Tests Data" core entity that I also created. However this "DCP Testing" grid does not appear under the list of available grids when I go to edit the step. I originally tried using an existing grid that is used in a separate configuration pack, but this was also not appearing. I have gone through and checked to make sure every part of the grid is listed as "Active," but it still does not show up. If anyone has any pointers or further aspects I should check it would be greatly appreciated. Thanks.
Hi Barrett,
Thanks for asking about this. I'd need to take a closer look at the profile to work it out. Can you export the Configuration Pack by going to System>Configuration Packs>Select the pack>Export pack.
Please then log and SR and attach the config file. I'll also need to know the profile name and the details for the tables you want in the SR.
Martyn
Thank you for the response. Unfortunately I could not attach the configuration pack to this message itself, so instead I have attached a link to download it. The profile name in question is "Crawford Truck-DCP Log COMING SOON" (named such so that our engineer's will not try to use it while it is in development). I am a little confused what you mean when you ask me to "then log and SR" as well as the "details for the tables you want in the SR". If you could clarify these points I would be happy to assist further.
https://crawford-inc.box.com/s/s9atbsn8lj1st06rq2nr7giio4iguurn
Thank You,
Barrett
Just curious if you saw my response or had a chance to look in to this issue for me.
Thanks.
