When I try to import CPTs into OpenGround from a gINT file, I receive an error stating that the "Imported Depth Column" and the "Elevation Column" have too large a scale. Any suggestions on how to alter the scale of these columns to correct this issue, or other suggestions for importing CPTs from gINT into OpenGround?
Jeremy
Hi Jeremy,
Thanks for asking about this. I think it will be the decimal places in the results for those fields. Check the decimal places in the file for those fields and ensure the data is set to 2DP.
Martyn
