Anyone know how to make an imported report template editable? I have imported the 'enhanced rotary core log' from the components web portal. However when I check config in the configuration the 'Enhanced Log' is not editable and the option greyed out. I therefore cannot make further changes in the Template Studio. The report template was imported as a .hbc. Any help appreciated.
Ultimately I was want to create a simple rotary core log which has a separate column for in-situ test / discontinuity info.
Hi Gaving
I can't find any edible Enhanced logs. I will keep searching and let you know if we have any
Hi Gavin
I'm afraid we don't have any editable versions of the Enhanced logs that are compatible with Template Studio, we only have the non editable available. I can add this as a wishlist item, but cannot give you a time frame for this I'm afraid
