I want to calculate sensitivity ratio = peak result / residual result and round up this number to the nearest integer.
I need a 'Roundup()' or 'Round()' expression
Hi Kiyan, I believe the Ceiling() function will do what you are looking for.
Hi Jesse,This seems to work for OpenGround Professional but not for Cloud Data EntryThe Ceiling() function refuses to save
Hi Kiyan,
You would need the expression for SSR to be in Calculated Value instead of Default Value.
Also, please check the field references in your expression. I believe it should be [ResidualresultValue] instead of [Resultresidualvalue].
Hi Jesse: I have changed the code and placed it in the Calculated Value blockCeiling([ResultValue]/[ResultresidualValue])
I think the issue now is that when I press Finish the change does not save and I am left with:
That is odd. I tested above expressions and Ceiling() saved for me without problem.
The only issue I see in your expression is that the field reference for [ResidualresultValue] still seems off.
I don't think that would cause Ceiling() to get stripped so I'm not sure what is happening.
One thing to keep in mind is that if you have the expression in Professional, that value will override the Calculated Value in Data Collector anyway. You just won't be able to see the Calculated Value in Data Collector until you sync.
(And one other thing you may want to be careful of is that in Professional, your Result Value and Residual Result Value fields may be calculated by default based off the Result and Residual Result fields. You may want to deactivate those calculations or change your Data Collector profile accordingly. Although I don't think that's related to above issue.)
It turns out there was an issue with saving expressions that only impacted users on clouds in Azure data centers. I believe you are in ANZ, so that would impact you.
It has now been fixed, so the expression should save properly now.
Hi Jesse, thanks for that. I will try it out and let you know
