My company has an existing config pack setup and applied to a particular project. When importing AGS Data (Data>Import Data) 'AGS 3.1' is provided as a file format I can specify with an existing mapping available (a particular version of AGS3.1 used by the roads authority in NSW, Australia, in case it is relevant).
I want to export this as XML to make changes (Configuration>Transfer Mapping>Download Import XML Mapping) but AGS 3.1 is not available as a file format I can select from the drop down. Screenshots below
Hi
Thanks for asking about this. The 3.1 import mapping cant be exported I think because of how the data imports and converts/links to the AGS4 format.
Martyn
Could you explain what you meant by 'because of how the data imports... to the AGS4 format'? Does OG import AGS3.1 files using an AGS4 mapping as an intermediary?
The dataset I am working with is in a modified version of the AGS3.1 format and one of the guides mentioned Bentley support could help write up a mapping file. Are you able to help with this? AGS specification attached.
PDF
