When adding a new office and logo, the logo image does not save. I can delete images successfully for existing offices and add new offices, but cannot save new images.
OpenGround Professional > System > Manage Offices > Edit Office
Hi Tony
Thanks for reporting this. I have repeated. I'll ask development and get back to you
This is a known issue and we are awaiting a fix. I cannot give you a time frame for this though, but development does know about the issue
A work around is to use Template Images and use a static image on the logs
Hi Melanie. Thanks for the note. I will be on the lookout for when we can return to normal intended use.
Mel,
This is a major issue for us. We definitely need to be able to use different logos for different projects and offices to get some current logs out. We would have to make hundreds of additional logs if this is not resolved soon. Can you please raise the priority on this issue?
Melanie
Hi Melanie,
Development is aware of this issue and is actively working on it. We are expecting a release of the fix very shortly.
