This is the error I am receiving when trying to import an ags export.
Type,Area,Message
"Error","Source Data","Unit 'yyyy-mm-dd' does not exist in the units table (Line: 37, Position: 37:0 to 37:0)"
Thank you,
-Krendon
Hi Krendon, The error means it cant find that unit in the unit table. You can open the AGS file and manually add the unit to the unit table and then save the changes to the file.
Martyn
Thank you, I was able to save and upload the log as a .csv instead. I will keep your solution in mind to try the next time I import logs.
May I ask where the "Unit" table is located in the gINT editor? I am only able to edit units in each table heading in the "Project Database" tab. Is there a "Unit" tab?
