I have previously had a professional version of OpenGround but it is now too expensive. I still have a project set as 'current' which is relic from the professional browser. The data entry app does not let me change a project to or from 'current'.
As it is no longer an active project, I would like to remove it from my list of current projects and add a new project as my current. It would seem reasonable that someone who is entering data might be doing so on the same project consistently, so would need a 'current' project on the data entry app.
Hi Adam,
Thanks for asking about this. You can only set/remove a project as current in HoleBASE.
Open HoleBASE and select the project, then select the "Toggle Current" option from the ribbon. This will remove that selected project as current, you can then assign another. You can also set multiple projects as current.
Martyn
Hi Martyn, do you mean to say HoleBASE? I'm not sure how this would work as there aren't licences anymore. Can I log in to HoleBASE with Bentley?
You can get a HoleBASE licence through Bentley.
I thought you was originally talking about the HoleBASE Data Entry Tool. Did you mean something else?
Yeah, I meant Bentley OpenGround Cloud Connect Edition Data Entry,
Thanks. Either way, if its OG or HoleBASE CE desktop you can use the toggle current option to select which projects are current.
