I want the "USCS" and the "Legend Code" to always match so our drillers don't always have to put the same value in each box since our legend code will always match whatever they choose for the USCS.
Hi Dylan, in the profile you can set the one to pull the data from the other using the Calculated Value option. Add the field name in brackets to the Calculated Field box and it should then pull the value across. The user guide should have some more information on this Data Collector (bentley.com)
