Is there a way to print all boring logs into on single pdf file? As of now, I can only find the option to individually save a pdf of each boring when I view the quick logs.
How do you do it if there are more borings than will fit on the first page of the boring list interface? . Holding the shift key doesn't work across multiple pages of the borings list UI.
Hi Richard, If you go to Preferences>Grids, you can change the number of Rows shown per page in the grid. Hopefully that will let you increase it enough to select all your Locations.
