I saved several quick section lines in the map tab in professional, but when I click to show them on the map, I can't edit them, or get the actual quick section to be produced.
Hi Dylan,
Just to verify if the section lines show on the map you will need to click on the "Select button" before trying to select the section line. Below is a quick video.
Some other helpful information regarding sections
If this information does not help. You can file a service request . Please provide current contact information and we can troubleshoot further. Login with you current Bentley User Name and password
Answer Verified By: Dylan Jenkins
Yep, it was the select tool not being selected. Thanks for the help!
