entering data into defect spacing column
Hi Martyn, I think I may have solved this one - it is entered in fracture spacing and appears as defect spacing, so not labelled the same. I cannot work out how it is supposed to be displayed though - as a number (FI) per run or per m? No data is appearing in that column, just the depth boundaries I have set
Hi Rachel, Its per m. If you hover over the column the tooltip suggests its m.
Martyn
