Studio - 'if' function syntax
Hi all,
I'm running into an issue with the 'if' statements on Template Studio that is unintuitive to me. I input the following expression:
if([LocationDetails.CoordinateDisplay] = 'Lat/Long',
     textStyle('Latitude: ', '700', 'Normal', '000000') + fixed([LocationDetails.LatitudeNumeric], 6, true), '')
When I tried previewing the results of this expression, I noticed that the entirety of the expression does not print if [LocationDetails.LatitudeNumeric] does not contain data. In my head, textStyle('Latitude: ', '700', 'Normal', '000000') should still print Latitude: so long as [LocationDetails.CoordinateDisplay] = 'Lat/Long' even if [LocationDetails.LatitudeNumeric] is empty.
In the photos attached, you can see that the expression works if I remove [LocationDetails.LatitudeNumeric] from the expression.
  • Hi Joseph,
    Im not familiar with CoordinateDisplay, is that a custom field?
    You can try breaking it down and make sure each bit works on its own. Try:
    if([LocationDetails.CoordinateDisplay] = 'Lat/Long','T'. 'F')
    If the above doesnt work then the issue will be with the first bit.
    You can also try these bits as well:
    and
    If the fields are valid fields, I think they will work.
    Martyn
  • Hi Martyn,
    Thanks for your response!
    Yes, CoordinateDisplay is a custom field. It's just a pick list with two options 1). Lat/Long and 2). Northing/Easting
    I've tried all iterations of the fields by themselves and they work. The issue is only when they're placed in an if statement together, and [LocationDetails.LatitudeNumeric] retrieves an empty cell.
    I have resolved this issue by nesting if statements, the bug only occurs within the if statement that returns an empty data cell. See below:
    textStyle('Latitude: ', '700', 'Normal', '000000') + if(isblank([LocationDetails.Latitude]), '', fixed([LocationDetails.Latitude], 3, true)),
    Cheers,
    Answer Verified By: Joseph Ang
Reply
  • Hi Martyn,
    Cheers,
