Grouping/Filtering Multiple Tables in the Excel Extension?
Hi, I'm trying to design a report template in the Excel Extension.  I have multiple tables in this report that I would like to be able to group and filter by borehole.  However, it seems that for multiple tables, you have to reselect the boreholes you want for each different table.  Is there a way to set the filter to apply to all of the tables in the sheet, or are you simply required to reselect the same boreholes for each table?
