Hi all,
I was looking at the built lab test assignment wizard in OpenGround Professional and stumbled upon this bug. The test schedule does not save lab tests assigned. See documentation below.
1. Create test schedule
2. Select Samples, then assign lab tests
3. Hit Save
4. Select Manage Schedule, and edit tests.
5. Lab Tests Assigned are missing
6. Re-add test type.
7. Previously assigned lab tests are not saved
Hi Joseph,
I've been testing this but unable to repeat. Can you confirm you are still having issues with this?
Martyn
Yes, the bug still occurs when I try the same procedure. In addition, I noticed that the lab test result within the schedules folder gets updated, however it does not show which samples are assigned which lab test.
A fix for this has been released today.
Please let us know if any issues continue.
