Hi all,
I am trying show default sieve sizes on the PSD - Data table within OG Data Entry, so that data entry staff do not have to enter sieve sizes. I noticed on the OG wikipedia the following page: https://communities.bentley.com/products/geotechnical1/w/openground-wiki/53849/are-there-any-example-default-value-expressions-for-data-entry
Are there any other default expressions available? What is the full list? This link only shows count(), max, and if statements. Right now I think I can tackle the above problem by making many nested if statements that count the number of rows and print a sieve size based on the row number. This is still not ideal as I would like to just have all the rows already displayed, when the data is input into PSD General (the controller group/grid). Is there an elegant solution for this?
----Edit----
As mentioned by Martyn below, there is no elegant solution for this. While writing the default expression, I noticed that the default expression has a limited character count. For example when trying to copy the following expression in, it gets cut off at about 'No. 40'. This means even the inelegant solution is incomplete
if(count()=0,'3"','')+
if(count()=1,'2"','')+
if(count()=2,'1.5"','')+
if(count()=3,'1"','')+
if(count()=4,'3/4"','')+
if(count()=5,'3/8"','')+
if(count()=6,'No. 4','')+
if(count()=7,'No. 10','')+
if(count()=8,'No. 20','')+
if(count()=9,'No. 40','')+
if(count()=10,'No. 60','')+
if(count()=11,'No. 100','')+
if(count()=12,'No. 140','')+
if(count()=13,'No. 200','')
Hi Joseph,
At the moment we don't have a way to do this. I think Oliver has emailed you previously about this suggesting to import the data rather than trying to type it in as you do with gINT.
Thanks Martyn
Thanks for confirming Martyn, we will obviously try to import data when available, I am just trying to plan for instances where that is not possible.
Is there a list of default expressions available on OpenGround?
