Hi all,
I am looking into using an image grid on a borehole log template to show the location of the borehole. The current guides for image grid object usage are unclear.
I have the following questions:
Bentley support informed me that the Image data type is likely a leftover value from SQL coding and has no functional use. It will likely be removed in future updates.
As the Image Grid object usage was described in the original post edit, I'll close this post.
Answer Verified By: Joseph Ang
