I'm setting up access to the upload portal for external contractors to queue AGS data imports for single projects, but don't want them to see other projects.
I've not been able to find specific guidance on the Wiki page for this. I have tried creating a separate security group for a contractor with just 'queue import' rights, but this doesn't work as no projects are visible. Please can you advise on the workflow to grant single project access on the upload portal?
Matt
Hi Matt, I think the best option is to open the project they need access to and go to Project>Project Access, you can then give them access to that single project. If they need access to multiple project's, you can go to System>Manage Users>Select the user>User Access. Then assign the projects they need access to.
Martyn
