Hi all,
I'm looking for a full list of the formats available for the text function. Excel Functions
I know the basics from excel apply, however there appear to be some special formats that aren't standard. For example within the Discontinuities Data group in the Description header the function text([Discontinuities.DepthBase],'F2') is used. This appears to print values to 2 decimal points and then convert them to a string. What other non-standard formats are available?
In addition, how does the text function interact with different Data Types? From the forum post below, you can see that some Data Types go through arbitrary conversion factors before getting converted to text via the text() function. OG Template Studio - DataType Conversion Factors .
bump
