Hi all,
I am trying to make a TimeSpan header for entering rock coring run times. I have found that the TimeSpan data type is not functioning as intended, and am wondering if I am setting it up incorrectly. Please see example below.
RunTime header created with Units = hh:mm - hh:mm
Units displayed on OG Data Entry only show (hh:mm)
When data is saved in OG Data Entry, the second time is deleted
Attempt to edit the row again to confirm that the value was deleted.
Hi Joseph,
The field has the unit hh:mm, an example for this is 05:00. As it's a duration this would suggest it ran for 5 hours. I can see from your example the duration would be 1 hour as you want from 05:00 to 06:00, so the value you would enter is 01:00.
If you want to show the text "05:00 to 06:00" I think you will need to use a different field.
Martyn
Hi Martyn,
Thank you for responding. I think my confusion stems from the units shown (hh:mm - hh:mm) when setting up the TimeSpan Data Type header. Duration is the only Display Type allowed for the TimeSpan Data Type, and all the units available in the dropdown menu show a range, which does not correctly represent how the Duration Display Type is used.
In addition, for the DateTime Data Type with the Time Display Type, the only available units are hh:mm:ss - hh:mm:ss. In this scenario I do not want to include seconds. I haven't tested this yet, however I suspect that although the units are hh:mm:ss - hh:mm:ss, OpenGround validation would delete the second value if one were to type a range.
I chose not to use a String Data Type to set up these headers because I wanted to borrow the strength of OpenGround display type validation to reduce typos made by data entry staff.
I have already completed this task with the Duration Display Type, however, Is there a Data Type and Display Type that can achieve this? If not, can OpenGround users create custom Display Types?
I just realized that Units are almost always written as 'units abbreviation - units', for example 'ft - feet' or 'percentage - %', and therefore the Time, TimeSpan, and DateTime data types are working as intended although confusing.
In the instance of 'hh:mm - hh:mm' this is confusing to users as it implies a time range, but in actuality does not. I recommend revising the units descriptions for all DateTime, Time, TimeSpan, etc so that the units shown in the heading window are as follows for new configuration packages.
