I seem to be getting an error when I test the links in the WMS connection:
Hi Michael, can you confirm what coordinate system is used in the project?
Martyn
Hi Michael,
Thanks, can you check what the project is using? Select the project and go to Project Details, then select the Configuration tab. You should see the coordinate system used for the project.
