I'm going through templates in template studio, that were provided to me by another, with the goal of explaining in simple terms what the reports are reporting.
When I am in the template studio, the cells are incredibly hard to read, and there seems no way of expanding the text such that I can read it.
See image below for an example of what I'm talking about. [Range Data Text] is readable, but the column to the left is unreadable.
Any tips for quickly understanding what's in a report template?
Hi Chris, the columns you cant read are "Backfill" and "Installation". To read these you could adjust the columns size. I don't think there is another method.
Martyn
Answer Verified By: Christopher Schaal
Thanks Martyn! Useful tip on adjusting the column size. I can do that then just re open the file without changing the format of the report.
