Master strip sets not working when saved to a project
I'm getting an error with a Master template, when trying to save it to a project.
The strip set I had previously set up disappears.
Start with a Typical Master Borelog template, with a strip set.
>Save to project: Of course you can't save a template developed in the Config pack to a project directly, you must save locally first.
>Save Locally: Once saved locally the strip set information is deleted and the error message shows up.
>Now Save to Project: Template saves ok, but strip set is still broken and the same error message shows up.
Are Master templates not inteded to be saved to projects? there is no mention of this limitation in the documentation.
NOTE: What happened to the user documentation pdfs? I remember some well organized documents from back in the Holebase days. I can't find them.
