OG Professional - Parent property must be set - Data Import Error
I am trying to import gradation data into a project into the group Particle Size Distribution - Data. This group is a child group to Particle Size Distribution - General. When attempting to import the data, I run into the following error:
I've checked the spelling on all the headers within the csv file to confirm that is not the issue. I have no problems importing other groups that don't have parent/child relationships. Has anyone run into this error before and know how to resolve it?
  • Hi Joseph, It does look like its expecting a parent value. Check the parent table values match what's coming in from the child table.
    Looking at the screenshot my first thought is the depth values are missing the 2DP. If the parent records have the 2DP this I think could cause a problem.
    My second thought is the sample ref is blank but may have a value in the parent record. If it does the reference will need adding to the child records.
    If that doesn't help please log it as a Service Request with the data attached and we can test it further.
    Martyn
    Answer Verified By: Joseph Ang
Reply
    Martyn
