Vertical border and sample type, etc, extends below the footer
HI,
I'm a new user here and trying to debug an issue where the vertical components (borders, sample type, numbers, recovery, blow count data and Nvalue, etc.) extend below the bottom border.  In gINT, there use to be a set page depth screen and it could be the same for each bore hole.  That would solve the issue for the sampling, etc.  But for the borders extending, how can I debug that?
Thanks in advance.
Parents Reply Children
  • It's more of a work around than an actual fix.  The original issue is still logged as a bug
    Open Template Studio, select a project, then select the template.  Click on Design>Template Setup. At the bottom of the screen, in the Depth Area, change the Plot Area to one mm smaller, then Ok the change. Save the template.  Repeat to change the Plot area back to what it was, then save the change.  This should them remove the over lapping lines at the bottom of the template
