Is there a way to add more attributes to imported points for the Civil 3D Extension?
I'm trying to edit the header for my boring profiles to something different than the default "knx_strip_header".  Right now, the only attributes that seem to get imported from OpenGround are the strip_offset, strip_chainage, strip_groundlevel, strip_finaldepth, strip_northing, strip_easting, strip_locationId, and strip_locationtype.
I would like to be able to place the latitude and longitude in the header, as well as the date the boring was drilled, but that information doesn't seem to get imported into Civil3D from OpenGround.  Is there a way to add these things to the header and have them dynamically populate?
