Is there a way to colour the soil "Graphics bar"? From the options (see attached pdf), the only option is for the border colour, which impacts the border and not the graphic.
There are at least 100 colours on the Munsell Colour Chart. Coding would seem to be a significant task. Does anyone have any advice to take this on?
Thanks,Lambert
Hi Munsell, this article should help:How To Assign a colour to geology codes - OpenGround Wiki - OpenGround | gINT | Keynetix - Bentley CommunitiesMartyn
Hi Lambert,
You can download 2 hbc component files from this link. The download also includes an example PDF.
These can be imported into your config pack to add a Picklist with Munsell colors.
One hbc will add a "Munsell Colors" picklist with opaque images.
The other hbc will add a "Munsell Colors Transparent" picklist with semi-transparent images. The transparent images can be used in a similar fashion to what is described in this article to overlay the colors on pattern-based graphics. You would need to create a custom Picklist header for entering the Munsell Color. And you will need to add a Graphics Bar in Template Studio that references the Munsell Color header. It is important to use the "FitToWidth" option for this Graphics Bar, or the colors might be distorted.
