<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>How is the station/chainage calculated in the Civil 3D extension?</title><link>https://communities.bentley.com/products/geotechnical1/f/openground-forum/243891/how-is-the-station-chainage-calculated-in-the-civil-3d-extension</link><description>I&amp;#39;ve created a profile view of several borings on a project from a project alignment. The station ( chainage ) is correct on the profile itself, but the label in the header gives it a different station (chainage) than what the actual station is.</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: How is the station/chainage calculated in the Civil 3D extension?</title><link>https://communities.bentley.com/thread/761991?ContentTypeID=1</link><pubDate>Fri, 14 Apr 2023 13:17:34 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:70222b6f-2495-4ec6-974f-f41169aa9a46</guid><dc:creator>Taylor Elson</dc:creator><description>&lt;p&gt;Hi Dylan,&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;The offset and chainage should be the same as using the station/offset alignment label (i.e. perpendicular to the closest point on the alignment). Sometimes the extension won&amp;#39;t update the point properties properly if the alignment is moved after creation. One solution to try is to have the profile &amp;quot;Rebuild&amp;quot; the points and headers, one way is to change the profile style and switch it back. This causes the extension to rebuild all the strips and recalculate the header values.&lt;/p&gt;
&lt;p&gt;Taylor&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
