We are working with USACE and using Open ground for our Field efforts and lab data entry.
We need to transfer data to the USACE cloud after field work. I wanted to know if there are any standardized templates for USACE in Open Ground software ?
Hi Malik
You can ask USACE to export their default CSV files from OpenGround, you can then use then to add your data to, this can then be directly imported into OpenGround
Kind regards
Mel
