I can't create a log report or quick log. When I try to create a quick log, the error states " 'Depth Related Exploratory Hole Information' table does not contain any records for selected location. When I try the log report, the error states "The server failed to create the log report". The preview of the log in Template Studio looks fine. Any suggestions?
Hi Chris,
Its likely the location is a combined location and Pro wants to show it on a combined log but cant so its showing it on the single template.
First of all, open the project and go to the Depth related Exploratory Hole Table and add the depth values for each location type. For Example:
CP from 0 to 10
then
RC from 10 to 20.
Then when you do the log report it will use the combined template its trying to use.
I hope this helps.
Martyn
