I am in the process of a creating a Civil 3D template file for my company's geotechnical modeling use. I have connected to a random project within our OpenGround database so that I have some actual data to work with when creating various styles configuring settings for the template. The issue I am running into is that I cannot seem to disassociate the file from the test project. I feel like I have tried everything, including wiping the drawing completely (which seems like a mistake, because now I can't even get the test project data to come back). Is there some sort of database connection running in the background that I don't have access to? Please help.
Hi Tim, Once its connected to a drawing you cant disconnect it. You can link it to a new project using the command:
OGCloud_RelinkProject
Martyn
