I am using the Depth Related item "Vertical Scale" in Template Studio to add depth and elevation scales to report with a graph. I can adjust the spacing of grid lines for a given plot, but is it possible to adjust the spacing of the Long, Middle, and Short Markers in the Vertical Scale data item (which serves as the master vertical level for the entire report)?
The wiki says that a Long Marker is placed every one depth unit, Medium every one-half depth unit, and Short every one-tenth depth unit. Can any of these spacings be altered?
The attached image illustrates the issues I am running into with my report.
Thanks for any help you can provide.
Hi, unfortunately it is not currently possible to adjust the ranges of these depth marks. However, this is something we will be looking at improving as part of our work to ensure that OpenGround is as feature complete as gINT, although I am unable to give you a timeframe on this unfortunately. I hope this helps
Thank you for your reply. I did suspect this was the case, but thanks for the confirmation. I look forward to future improvements.
Hey Stephen, was this feature added? I was hoping to edit the tick mark frequency as well.
