In Situ Vane Tests import - issue
Hi OpenGroundUsers. We're trying to import in-situ vane shear data with both undisturbed and residual measurements. I have this issue that the undisturbed values are not being uploaded, while residual values are being uploaded. I have tried using other columns ([1] Result Value, [2] In Situ Vane Soil Strength, and [3]Result) in the csv to input the undisturbed measurements, but same issue that says "XXXXXXX will not be imported because no mapping could be found for this column".
Short-term fix: For now, I have been able to upload the undisturbed value in the Vane Type column since I am currently only uploading one Vane type. But this would be an issue in the future if we're going to have multiple vane types.
