We are evaluating transient pressures for a single feedermain. The feedermain has a single tie to the system and connects to a downstream reservoir. However there are a few ties from the pump station at water source (the only one in the system) to the connecting point with the feedermain.
What are the common practices to simplify the network model in this case for transient analysis?
Hailiang
Thanks Jesse for the response. It is very helpful. I attached a sketch. I am trying to find way(s) to simplify the network for transient study. As you can see from the sketch, our work scope is only a small portion of the system (the system is slightly over 1000 nodes). In addition as you mentioned re steady state results, if I include the entire system in modelling, I am also including the uncertainty of the network steady state results.
Answer Verified By: shenh
