HI,
In Sewergems , i want the value of the drop of the manhole doesn't exceed a specific value .
for example if there is a drop with value 2 m and i want 1m to be the max value , so if i want to make this manually i will make many drops before the original drop with small values till when i reach the original drop it will be less than 1 m .in the attached picture , the red line is the current situation , and the blue line is what i want to do .
