I have created a UDF program with multiple studies, areas, and events and I am looking for a convenient way to export all the event elements (pipe runs, closed valves, hydrants flowed) as well as the results (min pressure, travel time, volume). Currently I can only export the results by area and the event elements by individual event. I have large number of events and am looking for a quicker method.
The end goal is a spread sheet that has each event in a row and with closed valves, hydrant, flow, pipe runs, flushing time etc. in the columns.
Any thoughts or Ideas to save some time would be great.
Ryan Stackpole
Hello Ryan,
Most likely you are aware of it, but there is a button at the top of the Flushing manager to generate a Flushing Report. These reports have been designed so that they can be printed out and provided to the field operations crew. We'd be interested in any feedback you have on that report - was it missing something you needed? Or, are you wanting to export to Excel for other reason?
Some other thoughts:
1) The aforementioned reports can be exported to Excel. With the report open, click the Save button in the top right corner > Excel File. Of course, this might not be formatted exactly the way you need.
2) The Flushing Results Browser (Analysis > Flushing Results Browser) lists each event and some details like the length of pipe that met target, min pressure, travel time, volume, etc. You can also export this to Excel.
3) This one is quite advanced, but you could in theory export the components of the Flushing studies to spreadsheet by setting up a Modelbuilder connection (Tools > ModelBuilder. You would set up the spreadsheet ahead of time with tables that have column headers but no rows, then configure the table types and field mappings in Modelbuilder, then "sync out" to the spreadsheet. Here's a rundown of the various Table Types related to flushing, and some notable fields that can be mapped:
Area - label, notes, flushing study, representative scenario, output scenarioFlushing Event - label, flushing type, notes, report viewsFlushing study - label, notesFlushing Report View - label, flushing area, flushing event, notes, Is Primary View?Flushing Event, Flushing Events Collection - Element label, element type, flow, status, notes
You can find more information on Modelbuilder in the Help and in this article:
Building A Model Using ModelBuilder
Let us know if these suggestions help and we'll document it as a Support Solution. I can also pass your feedback along for consideration in a future release.
Ryan, I also see that you also submitted a Service Request with the same question. I noticed you entered SELECTseries 4 as the version. You may be interested to see the improvements we've made to Flushing in SELECTseries 6:
What's new in WaterGEMS and WaterCAD V8i SELECTseries 6?
Flushing in WaterGEMS/CAD Select Series 6 +
I have also documented the workaround in the following Support Solution:
Exporting Flushing results to Excel or other standard format
