The Flow/Capacity design while designing sewer using Darcy-Weisbach method goes upto 102%.
Can any one please tell why it happens? When we use manning's for designing sewer network Flow/Capacity design is restricted to 100%.
Best Regards
Jatin Talwar
Hello Jatin,
There might not be a better design available with the constraints defined.
Check the diameter of the conduit that has a "Flow/Capacity (Design)" of 102%.Check your conduit catalog to see if there is a larger diameter available for design.
If that is not the reason then please provide the model files so we can see all of the constraints in your design.See: Sharing Hydraulic Model Files on the Haestad Forum
Craig Calvin
Bentley Technical Support
Please provide the model files using one of the options in the link below.
