I'm having a problem with Sewergems Connect. When using the SWMM engine I can create hot start files, However when using the hot start files I don't get any flow results. Quite strange.
Anybody have any thoughts on how to fix this?
Craig
Craig,
I tested this and I'm not having the same problem that you've reported. Can you upload the model and hot start file you're having trouble with? The directions to upload a file can be found in this wiki.
Mark
