Hi this is Suseendar , I am using SewerGEMS V8i (SELECT Series 5), Somehow my Predefined Queries were deleted , Please help me to bring back predefined queries set. Thanks in advance.
Sushma Choure
Bentley Technical Suppport
Answer Verified By: Suseendar Ramadoss
In addition to what Sushma suggested, restoring a backup files is another solution for this problem if this should happen to flextables, shared queries, or another component of the software. For example, to restore a backup for Predefined Queries go to "C:\ProgramData\Bentley\SewerGEMS\8" then locate the file called "PredefinedQueries.bak". If you remove the .bak file as the extension and change that to .xml it should resolve the problem.
Mark
