What is the most proper way to model a sewage air valve in Hammer (double acting) with an inflow check valve? (no air in, only air out).
Hi Thanasis,
Although it may be possible to use an air inflow orifice diameter of zero with the air valve node element, I have not seen this attempted and it seems like an unusual case to me. Typically an air valve is used in a transient context to allow free air inflow to keep the water column moving, to help mitigate a "downsurge" in the vicinity of the air valve. So, the air valve is typically configured with a larger air inflow orifice to allow air in quickly, and then a smaller air outflow orifice to prevent air from being expelled too quickly.
Perhaps what you are describing is an air valve that is only used to release air that may naturally accumulate at high points? If so, then you may not need to model this in HAMMER and could just use a junction.
If this does serve a purpose for transient mitigation, or is a factor in the transient response of your system, I am curious about exactly how it works and what you expect it to do. What are the starting conditions in the initial steady state, what happens during your transient event, and how does this air valve respond?
You can read more about the different types of air valves available in HAMMER here:
Modeling Reference - Air Valves
