what that error means and how to fix it User Notifications.csv
Hello Mahmoud,
If you are using catch basins in the model, then you need to set the default values for maximum spread and maximum gutter depth in the default design constraints.
If you are using StormCAD V8i, then go to Components<Default Design Constraints>Inlet tab.
If you are using Connect Edition version, then go to Analysis>Design Constraints>Inlet Tab
Sushma Choure
Bentley Technical Suppport
Answer Verified By: Jesse Dringoli
